ISC Monroe/Rancho Shock Replacement PN's?
Old May 12, 2013 | 05:55 PM
etherpool's Avatar
Default ISC Monroe/Rancho Shock Replacement PN's?
I've done a search but can only find outdated part numbers. I've got a 2000 Rodeo 4WD with the ISC. All 4 shocks are blown and I want to go standard. Any idea of the Monroe or Rancho part numbers? I've also seen some conflicting info on if standard Monroe sensatracs are a direct bolt on replacement for the ISC shocks. Can someone confirm? I know the rears are different.
Thanks!!
Old May 17, 2013 | 02:24 AM
leee258's Avatar
The Max-AirŽ shock absorber is ideal for vehicles that haul heavy loads or tow trailers. Designed to maintain level vehicle height, they can be inflated or deflated as needed...from 20 psi to 150 psi with the vehicle loaded.
Packed in pairs that include air line, air fittings, and air fill kit.
2013 MERCEDES BENZ SL-CLASS
Old May 20, 2013 | 02:04 PM
Windy's Avatar
I just put in new monroes:
Front - 37159
Rear - 37024
perfect fit.... though the rear ones seem a little too soft (when loaded with three passengers in the back) although I think they originally are for Trooper
s
would like to find out about the correct Rancho part# for the rear as well....
Regulrguy
Jul 26, 2012 06:24 PM
ChuckP
Jun 8, 2011 06:21 PM
humannail
Jul 23, 2010 04:27 PM
elvis156
Feb 11, 2010 01:45 AM
yamaha1001
Pickup
Jan 14, 2010 11:10 PM
