High Idle question... Please help yall!
Old Dec 2, 2010 | 05:21 AM
wasim's Avatar
Default High Idle question... Please help yall!
1995 Isuzu Rodeo, 3.0L V6, 4WD, 5-Speed....Grey... (joke)
I got the truck from a friend with a high idle around 2000 rpm's...
I changed out the fuel position sensor( at least thats what I think it was) and it went down, but then started bogging out, as I pressed the accelerator and as i was letting off...
Then I needed a new battery so I picked one up and as soon as I finished installing it, the high idle came back with even more terror, idling between 2500 and 3000 rpm's which is just ridiculous.
Throttle cable is fine, not the problem... I was told that
I could try a new catalytic converter but it would be a pain in the butt and I'd have to find someone to weld it on for me unless i spent an arm and a leg to get a new bolt on one.
If you have any idea what might be causing this specifically, or you know exactly what it is, please help!
all information is much appreciated! I can't wait to get this bad boy running right so i can go off-roading!
Trust Deed
Trust Deeds
91SpaceCab
Mar 3, 2012 05:16 PM
AnthonyRodeo
Dec 1, 2010 09:29 PM
lucky guy
Oct 3, 2009 01:10 PM
tudman70
Dec 10, 2007 09:17 PM
t429258
Mar 24, 2006 02:43 PM
