Help Bleeding Slave Cylinder
Old Jul 11, 2011 | 09:37 PM
MEC's Avatar
MEC
Question Help Bleeding Slave Cylinder
Need help on the proper way to bleed the slave cylinder and clutch master cylinder on my 99 Rodeo 5-speed 4cyl.
Old Jul 19, 2011 | 11:29 AM
StanZ's Avatar
Default Clutch bleeding instructions
`Here are the bleed instructions from my Hayes manual.
Caution Do not allow the brake fluid to contact any painted surface of the vehicle, as damage to the finish will result
1 Bleeding will be required whenever the hydraulic system has been dismantled and reassembled and air has entered the system.
2 First fill the fluid reservoir with clean brake fluid which has been stored in an airtight container. Never use fluid which has drained from the system or has bled out previously, as it may contain grit and moisture
3 Attach a rubber or plastic bleed tube to the bleeder screw on the release cylinder and immerse the open end of the tube in a glass jar containing an inch or two of clean brake fluid
4 Open the bleeder screw about half a turn and have an assistant depress the clutch pedal completely. Tighten the screw and then have the clutch pedal slowly released completely. Repeat this sequence of operations until air bubbles are no longer ejected from the open end of the tube beneath the fluid in the jar.
5 After two or three strokes of the pedal, make sure the fluid level in the reservoir has not fallen too low. Keep it full of fresh fluid, otherwise air will be drawn into the system.
6 Tighten the bleeder screw on a pedal down stroke (do not overtighten it), remove the bleed tube and jar, top-up the reservoir and install the cap
7 If an assistant is not available, alternative 'one-man' bleeding operations can be carried out using a bleed tube equipped with a one-way valve or a pressure bleed kit, both of which should be used in accordance with the manufacturer's instructions.
As best I can tell, you only bleed the slave cylinder. Air in the master should just come up into the reservoir and escape on its own.
genso
Apr 7, 2009 03:17 PM
robb5
Feb 13, 2009 05:29 PM
sunrisetrooper
Jul 15, 2008 09:15 PM
doc182
Private 'Wanted' Classifieds
4
Jul 27, 2007 05:22 AM
trooper90
Dec 1, 2006 04:49 PM
