Grinding sound
Old Aug 17, 2007 | 01:30 AM
rja4u's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Hello Zoo fans!
While driving my 5 speed 1993 rodeo, whenI let off the gas there's a loud grinding gear sound, when I speed up theres the same sound. When I press the clutch the sound goes away, when I coast in neutral there is no sound.
Could someone give me a hint to what this could be, before I am forced to goto one of these high priced shops.
Old Aug 21, 2007 | 11:46 AM
NCISUZUTECH's Avatar
Do you know which tranny you have and is the noise in all gear ranges or does it go away in any gear,(like maybe 4th)?
Old Aug 21, 2007 | 06:01 PM
Since its a '93 and 5 speed I would say its an MAU5. Sounds like the throw out bearing for the clutch is bad. They are usually replaced along with the clutch and pressure plate. Might as well do it all at once while in there. I'm not positive that its the problem though without hearing it.
What happens when sitting still in neutral and pushing/letting off the clutch? Do you get the noise with the clutch out and stops with the clutch in?
Edited by: Gizmo42
Old Aug 22, 2007 | 12:00 PM
If the noise goes away in 4th gear it is most likely the input gear worn out. It will sound just like a throw out bearing but the throw out bearing will still be there in 4th.
Old Aug 24, 2007 | 03:28 AM
rja4u's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Everyone,
Thanks for the input. The sound is made in all gears including 4th gear. I plan on checking out the clutch assembly during Labor day weekend.
Once again thanks, and I welcome anymore suggest about this problem.
mudsnipe
Dec 30, 2010 07:59 PM
thgindim
Isuzu Pickup, i-350 and 1-280
Sep 9, 2009 04:34 AM
HokieAmigo98
Oct 23, 2008 03:11 PM
epoch
Nov 22, 2007 10:45 AM
soberinutah
Jul 16, 2007 02:59 PM
