Gas gauge
Same year here with same problem. Shops around here don't sell just the unit by itself. The ones I've seen on eBay look iffy. Where could I get one? Or who has gotten a good one off eBay. If so any recommendations?
Thanks
Thanks
like mentioned in another post I got one of those 30 dollar ones from ebay, came in a plastic bag in an envelope, didn't look anywhere near official or legit but works fine ever since.
If you don't wanna mess with that the simplest fix would be a square inch of electric tape over the blinking light or a cleaner 15min fix is to take the bulb out
Fuel light is flashing? I didnt know they did that! LOL, Guess I never let it get low enough or maybe it just doesnt work...
But yeah, sounds like a classic case of the fuel level sending unit. Since you have to drop the tank, run it until its almost outta gas. ALOT easier to work with without an extra 100 lbs or so of fuel in it, haha.
Good luck
Good luck
Found one off eBay that is oem, or so they say.
Will see what happens.
I'm not sure if and/or how the wrong signal of the fuel sending unit influences the whole injection system, but when mine went it was the only code in the system and the car was running great with actually better mileage. Now an exhaust leak will make your mileage go down to sea level, every time I got one I barely make 15mpg, fix it and back up to 19-20 right away!
awnicol25
Nov 10, 2006 06:03 PM
awnicol25
Aug 29, 2006 10:56 AM
awnicol25
Aug 25, 2006 11:03 AM
