Engine knock over 2K RPM
Old Nov 3, 2007 | 08:17 PM
silencesnow111's Avatar
With the new issue that I now have, has anyone else suffered a knock that starts around 2000 r.p.m.'s and wont stop until its back to idle? Im just wondering what anyone has found to be the problem? (bearing? seals? etc.)
Old Nov 3, 2007 | 10:26 PM
Keefbikes's Avatar
a knock or a click?
Old Nov 3, 2007 | 10:41 PM
A knock. I wish it was as light as a click. I can put my hand on the valve cover and rev the motor and feel it. I did hope at first it was just the common lifter clicking. But no.[img]smileys/smiley19.gif[/img]
Old Nov 17, 2007 | 10:34 PM
If the timing belt tensioner goes bad (which is common) it can sound alot like a rod knock. Gets misdiagnosed alot. Could be a rod knock though.
Old Feb 1, 2022 | 11:48 PM
Badcard's Avatar
Default Timing belt stretched or bad tensioner
I agree with the guy about the timing belt tensioner and what will happen next is your timing belt will go through the timing belt cover so check it out I know this from experience
gorewhore
Mar 31, 2011 01:19 PM
armen_k1979
May 26, 2009 12:46 AM
unklb
Jan 28, 2009 12:39 AM
rhillman75
Jan 27, 2009 10:25 PM
