Dying Sunroof?
The sunroof mechanism on my beloved 2002 Rodeo LSE has started making a loud clicking sound just as the roof slides to a full close. My garage says that this means the whole sunroof will have to be replaced (at a cost of over a thousand bucks) and that I should "just stop using it".
Huh? I have heard that there are lots of problems with the Rodeo sunroof, though I didn't find any here. Can anyone offer a diagnosis/fix? Thanks! |
Sorry, I can only ride along with you and the same problem on a 2001 Rodeo LS, except my sunroof seems to be in the advanced stage and refuses to move at all. Though every once a while it will do the lift-open with a loud crack, and once it actually did slide back again after riding a real rough road but its stuck again. So please - any remedies out there without spending a thousand bucks :( ?
I think its better to take your car to the local mechanic and get it solved.He will not charge you lots of money.
I had a similar issue with my 01 LSE. Take a look at both insides from outside the care with the sunroof tilted up. There a a couple of clips with screws on them on both sides. One side of mine was off the track and I was able to get it back on. Worth a check out.
Ummm....what?
Thanks for your suggestion, Leto, but I'm still stumped.
I tilted open the sunroof, and then stood on the running board of the car to try to see what you mean...........but the panel only tilts up about 8 cm, so I can't see anything on the tracks. Can you maybe send me a photo? Thanks so much!:) |
Hope this helps...
Originally Posted by kkyco
(Post 42506)
