-   -   Cold Start Issue (https://isuzuforums.com/forum/rodeo-17/cold-start-issue-1517/)
Annihilator Nov 19, 2007 03:41 PM
Well after installing a new battery, plugs, cap/rotor, IAC, fuel filter, and air filter, the car still runs rough when cold for a bunch of seconds and sometimes stalls. Any ideas? TPS?
Gizmo42 Nov 19, 2007 07:54 PM
Could be a dirty IAC (idle air control). Its supposed to help richen the mixture when cold the way a choke used to on carbed engines.
jetmech09 Nov 21, 2007 01:50 PM
I agree[img]smileys/smiley2.gif[/img]
Annihilator Nov 21, 2007 04:15 PM
Well the IAC is new and I reset it to make sure.
Gizmo42 Nov 21, 2007 08:48 PM
Oops[img]smileys/smiley9.gif[/img] missed in the first post you said you did that. Umm.. fuel pressure regulator, coolant temp sensor, intake manifold gasket, tps, not sure what else would cause it.
jetmech09 Nov 21, 2007 09:14 PM
make sure you plugs are the Iridium type.I had the same issue and Iridium plugs cured it.
