Cold Start Issue
Old Nov 19, 2007 | 03:41 PM
Annihilator's Avatar
Well after installing a new battery, plugs, cap/rotor, IAC, fuel filter, and air filter, the car still runs rough when cold for a bunch of seconds and sometimes stalls. Any ideas? TPS?
Old Nov 19, 2007 | 07:54 PM
Could be a dirty IAC (idle air control). Its supposed to help richen the mixture when cold the way a choke used to on carbed engines.
Old Nov 21, 2007 | 01:50 PM
jetmech09's Avatar
I agree[img]smileys/smiley2.gif[/img]
Old Nov 21, 2007 | 04:15 PM
Well the IAC is new and I reset it to make sure.
Old Nov 21, 2007 | 08:48 PM
Oops[img]smileys/smiley9.gif[/img] missed in the first post you said you did that. Umm.. fuel pressure regulator, coolant temp sensor, intake manifold gasket, tps, not sure what else would cause it.
Old Nov 21, 2007 | 09:14 PM
jetmech09's Avatar
make sure you plugs are the Iridium type.I had the same issue and Iridium plugs cured it.
marcos49
Sep 28, 2010 03:26 PM
magickninja
Pickup
Nov 10, 2008 04:41 PM
tkp37
Nov 7, 2007 05:39 PM
dinotroop
Sep 14, 2007 10:18 AM
drew
Aug 15, 2005 03:34 PM
