Clicking Behind Rear Wheels
Old Nov 12, 2011 | 12:40 PM
brek08's Avatar
Default Clicking Behind Rear Wheels
have no idea what it is. Its coming from the back so i know its not the cv's. checked the brake hardware and it looks fine. could it be something to do with wheel seal or the diff?
Old Nov 12, 2011 | 12:43 PM
brek08's Avatar
Its a 95 4x4 by the way
Old Nov 22, 2011 | 04:28 PM
brek08's Avatar
figured it out. just replaced the rear seal and diff gasket and filled her up. it was probably just some wear on the spider gears but works great now. so if anyones having the same problem, there ya go.
Old Nov 23, 2011 | 03:30 AM
f10078's Avatar
just replaced both rear axle bearings still getting clunking noise when i test drove, did notice the pinion gear was a little loose when i replaced the pinion seal, what could cause the pinion gear to be loose on a 1996 rodeo w/dana diff?
Old Dec 9, 2011 | 09:51 AM
Taylorcarter's Avatar
Its looks like a great one. I feel it will be a good option only.
christen
Oct 19, 2011 01:49 AM
KoopaTrooper
Jul 26, 2011 08:27 AM
Drockstar
Oct 22, 2010 11:17 AM
jackc396
Jan 31, 2010 08:48 PM
