a/c turns off
Old Nov 15, 2010 | 07:02 PM
jetmech09's Avatar
Default a/c turns off
my airconditioner is turning off. Clutch will disingauge after a/c has been running. check freon level and pressures, all ok a/c kools great while it is running with no noise at compressor. is there some type of thermostate that may be going bad?
Old Dec 7, 2010 | 08:41 PM
hr2burn's Avatar
Weird, is this at idle or while driving. Many I have worked with, above a certain rpm, it will disengage ac clutch. Perhaps this sensor is bad?
Old Dec 8, 2010 | 04:51 PM
jetmech09's Avatar
it will do it at any time , its like freezing, maybe a dirty reciever dryer.
Old Dec 8, 2010 | 09:48 PM
RyJen's Avatar
May be a long shot, but I have the same issue with a Chevy Malibu. In the case of my Malibu (worst car ever made), its a malfunctioning switch inside the dash.
Old Dec 11, 2010 | 08:42 AM
jetmech09's Avatar
just checked the condenser fan and it only runs if the recycle switch is set to recycle. if I slide it over to outside air the condensor fan quits. what controls the condenser fan ?
schetk
Jan 13, 2009 08:57 PM
csanche2
Oct 23, 2008 10:03 PM
musicc
Jul 22, 2006 05:34 AM
Smiley
May 31, 2006 01:47 PM
robinsky
Aug 30, 2005 02:23 PM
