bluecollar needs help 99 rodeo
Old Jun 21, 2007 | 08:55 AM
tungsten1's Avatar
Have a 99 rodeo 4cyl manual (98kmiles). Bought it used. it has been a good work suv.Three weeks ago battery light came out and Ihadthe battery and alt changed. A week ago it would not startat a worksite. Looked at the fuses and the second top fuse from l to r (fuse box on the left side of the dboard) of the top ten-fuse row burned. I replaced it with a 25Amp and did ok. Yesterday the suv stopped cold on my way to a worksite. Yep, the same fuse had burned. I replaced w/ a 30 amp and went on my way but suspect it will burn again. What is this fuse for? I don't have a manual. Could it be a short?Any guidance will be appreciated.
Old Jun 24, 2007 | 05:50 PM
MASTERTECH's Avatar
don't put fuses of higher amperage in a lower amperage spot or you could find where that short is and damage the wiring harness right along with it, figure out what fuse it is and e-mail me back and I'll try to help you
Old Jun 27, 2007 | 12:29 PM
tungsten1's Avatar
Thank you mastertech. It was the 15A ignition control fuse. I took the rodeo to the mechanic and he changed an "ignition relay" but it kept shutting down. His diagnosis is that the computer may have gone kaput andthis whole things appears to be as resultof changing the alternator..possible? who knows..I need it for work so hpe to have it back in a couple of days...I'll keep postings. Thanks again.
Old Jun 30, 2007 | 10:05 PM
crashjt's Avatar
ya know the computer is pretty much the first thing to get blamed when a mech gets lost or confused i highly doubt that it is your problem I would seek another opinion as the pcm's "computers" in these isuzus are not typically problematic it is most likely a short in the harness rubbed or pinched wire something of that sort
houston_tx
Jan 3, 2009 11:44 PM
VP-TROOPER
Dec 11, 2008 12:26 PM
jakeworth
Dec 2, 2008 10:18 AM
Amigo3
Jan 4, 2007 01:45 PM
trooper90
Dec 1, 2006 04:49 PM
