ABS light and parking brake light on
Old Nov 18, 2011 | 11:48 PM
greggd1959's Avatar
Default ABS light and parking brake light on
I have a 97 Isuzu Rodeo, 4 cylinder, 215,000 miles and the ABS and Brake light have been on for over 5 years, no one can fix it. I noticed that the rear wheels seem to lock up when you have to slam on the brakes causing the car to skid badly. Question I have is in the engine compartment in the fuse box I noticed (2) 15 amp fuses listed and none in there and a 40amp small square fuse listed and its empty. Should there be fuses in there? Is that why this system dosent work? Also, can you disable the whole ABS system by unplugging the sensor on the rear differential to reverse the wheels locking up in the rear? Any help would be greatly appreciated.
Griff
Jul 31, 2013 01:20 PM
daveyboy43
Nov 12, 2012 06:02 PM
yhata
Jun 5, 2010 03:23 PM
leesnider
Jun 19, 2009 12:02 PM
greenhornet36
May 17, 2006 06:11 AM
