ABS Light on
Old Jan 6, 2013 | 02:52 AM
Thundare's Avatar
Default ABS Light on
So i have a 1999 Isuzu Rodeo 3.2 DOHC 5spd 2wd. I have the ABS light on and i have no experience fiddling with ABS. Is there a common part of the abs system on the 99 or do i have to have fun with this thing?
Old Jan 13, 2013 | 02:44 PM
Windy's Avatar
on mine ('00 v6) I found an easy-to-fix problem: the rear sensor (at least on mine) is in the differential, so there is a connector plug on the top of the diff towards the front. found a severed wire right there (about 2inches before the plug on one of the wires coming from the front), obviously those take a beating and seem to be a common spot to fail...
greggd1959
Nov 18, 2011 11:48 PM
yhata
Jun 5, 2010 03:23 PM
nwtraveler469
Feb 22, 2008 08:10 AM
Mr. Bad Wrench
Aug 18, 2005 07:07 PM
dane
Jun 29, 2005 07:08 PM
