99 rodeo 2.2 clutch problems
Old Mar 16, 2008 | 06:55 PM
99rodeo2.2pos's Avatar
i have a 99 rodeo 2.2 5 speed and i am having problems with the clutch,sometimes it will try to move if in gear with the clutch on the floor and its hard to get in first gear at times,i checked the slave cyl and it was worn badly so i replaced it,still had the same problem,so now i just replaced the clutch master cyl and STILL have the same thing going on. spent almost $200 so far and i'm at wits end. any ideas?
Old Mar 17, 2008 | 08:59 PM
ISUZUGURU's Avatar
Super Moderator
your clutch is not fully releasing,if you replaced the clutch with an aftermarket one the disc is proably too thick or there is somthing wrong with the psi plate.if you havent had the clutch replaced that is your next step an isuzu clutch kit.
_uacct = "UA-939292-44";
Old Mar 30, 2008 | 05:11 PM
I found the problem !!
the pilot bearing was frozen causing the shaft to keep turning with the engine. went ahead and put a complete clutch kit in and she's fine and dandy now !
hammerhead8819
Jun 2, 2010 06:25 PM
Azathoth
Apr 30, 2010 06:50 PM
DEEBEE
Feb 11, 2010 08:36 PM
Yasracer
IF Help & Suggestion Center
Feb 4, 2010 07:26 AM
Mikeross509
Jan 30, 2009 07:02 AM
