99 rodeo 2.2, anyone know torque specs?
what to torque the main/rod bolts to? how about the baffle? oil pan?
i just put new bearings in, and i need the torque specs before i put it all back together and tighten them up!
thanks in advance!
I may be too late but here are specs from haynes. They are to be tightened in stages. Dont see anything about the 'baffle'.
Balance Unit Retaining Bolts
step 1 168 in-lbs
step 2 45 deg rotation
Main Bearing Cap Bolts
step 1 36 ft-lbs
step 3 15 deg rotation
Connecting Rod Cap Bolts
step 1 25 ft-lbs
Oil Pan Bolts
step 1 70 in-lbs
step 2 30 deg rotation
Oil Pan Support Bolts
168 in-lbs
Hi Gizmo, can you add the torque spec for the throttle body of a 98 Trooper? I'm going to clean out the carbon junk buildup in the front pipe that may be causing my check engine light to be on. Thanks< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
