99 leaking coolant
my 99 v6 is leaking coolant from the front of the motor......it seams to becoming from a small black tube that goes into the back of the housing that the upper radiator hose connects to......any help????
look at the drivers side t-belt cover and see if you see coolant traces on the cover if so then that is it, it is not a very hard repair there are 5, 12mm head bolts and then you can pull it back and remove the o-ring and the gaskets and put it back together, make sure you put a little grease on the o-ring so you don't roll the ring
yes i do see coolant on the timming housing....so you helped me find the leak...thanks....also thanks for the idea for the grease...i'll let you know how the repair goes......thanks again
i repaired the cross over tube and it was an easy reapir....BUT when done i ran water over the top of the motor to clean and coolant away and saw what appears to be a new leak on the back of the motor???? i think it was the water that collected in the valley and ran back...after a few days the water stopped comming from the back of the motor but i still seam to smell antifreeze but no spots under car???? the smell drives me CRAZY....but i'm crazy about that kind of smell..i can seam to smell it only a little...the reason for the rant is that could i have damaged a diffrent seal working on the front cross over tube..the original leak was from the o ring that goes in to the front cross over tube..is there a rear o ring on that black tube???i goes under the intake and i can't see where it goes???? OR is the smell just from antifreeze left over from the repair and how can i rinse it away???
