95 Rodeo 4x4 not charging.
Hi. Well my girlfriend bought a Rodeo and I know absolutely nothing about them. The other day she was driving and it lost all power... Could barely even make it up our hill (gauges and cd player both lost power also) but still drove. I replaced the terminals and a brand new battery and still will start right up but lose power after a couple minutes and try to shut off, but I can keep it alive with gas. When it dies out, I try to start it back up and it won't do anything... barely enough power to use the windows. I bought a brand new alternator and put it on, it ran fine for about 15 minutes while it idled, and started doing the exact same thing. The only other thing I could think of was an external voltage regulator, but I found out that these are built into the alternator. If anybody has ANY ideas, please help. I'm extremely desperate. Thanks a lot.
What is the battery voltage accross the terminals when it dies?
What is the current amperage leaving the battery before and as it dies? do the headlight dim? or are they bright when it dies? |
Originally Posted by kdfvwman
(Post 8153)
'nother question:
are all ground cables in place and clean/tight connections to/from battery as well as engine to chassis? Alternator charge light on/off when running engine? |
(Post 8168)
'nother question:
are all ground cables in place and clean/tight connections to/from battery as well as engine to chassis? Alternator charge light on/off when running engine? I've checked every ground and from what I can tell they're all good. And I haven't seen an alternator charge light at all so I'm guessing it's off. |
Charging system
The 1995 Rodeo needs to have 4 good fuses: CB-3 ENGINE DEVICE, 15 AMP FUSE,CB-7 METER, 15 AMP FUSE IN DASH FUSE BOX ,
EB-16, MAIN 100 AMP FUSE AND EB-6 CHARGE, 10 AMPS IN ENGINE COMPARTMENT IN FUSE/RELAY BOX;...THERE IS ALSO A CHARGE RELAY WHICH MUST BE IN ORDER! THE WIRING DIAGRAM COMES OUT OF THE HAYNED REPAIR MANUAL, PAGE 12-22, SEND ME YOUR E MAIL ADDRESS SO THAT I CAN EMAIL YOU THIS WIRING DIAGRAM IF YOU WANT TO. HAPPY HUNTING AND KEEP IN TOUCH. KPFVWMAN |
(Post 8177)
Thethanks again. 1995 Rodeo needs to have 4 good fuses: CB-3 ENGINE DEVICE, 15 AMP FUSE,CB-7 METER, 15 AMP FUSE IN DASH FUSE BOX ,
EB-16, MAIN 100 AMP FUSE AND EB-6 CHARGE, 10 AMPS IN ENGINE COMPARTMENT IN FUSE/RELAY BOX;...THERE IS ALSO A CHARGE RELAY WHICH MUST BE IN ORDER! THE WIRING DIAGRAM COMES OUT OF THE HAYNED REPAIR MANUAL, PAGE 12-22, SEND ME YOUR E MAIL ADDRESS SO THAT I CAN EMAIL YOU THIS WIRING DIAGRAM IF YOU WANT TO. HAPPY HUNTING AND KEEP IN TOUCH. KPFVWMAN Thanks a lot. I'd really appreciate the wiring diagram. My e-mail is strungxout@hotmail.com . Thanks again. |
