94 Rodeo again..is Tranny going??
Old Mar 25, 2007 | 01:21 PM
cowboys78's Avatar
Now Im having another problem with my rodeo. The car will be driving fine then the engine sputters briefly and the check transmission light flashes for about 5 secs then turns off and car runs normal again...is tranny going? Any help would be appreciated!
Old Apr 14, 2007 | 02:33 PM
cowboys78's Avatar
bump
Old Apr 16, 2007 | 11:27 AM
ibguyb's Avatar
If you put the car in L1 does the car still shift up? If it does then the shift indicator switch probably is bad.
Old Jun 6, 2007 | 12:16 AM
cowboys78's Avatar
Yes, the car does shift up in L1...Im starting to think its something to do with the fuel pump and/or fuel filter...I almost ran out of gas the other day and as I was sputtering over a bridge towards a gas station on flat empty the trans. light was flashing...For some reason, the car will die on me while im driving it....could the car momentarily not get gas to the engine and die? Mysterious to me
Old Jun 6, 2007 | 10:52 PM
Dont let it get below 1/4 tank of gas. These have american made fuel pumps which need the fuel to cool it. Letting it get below 1/4 tank will over heat it and kill it if done too much.
Your fuel pump could be failing or you might have sucked up a bunch of crud and plugged the fuel filter.
Could also be an electriclal issue, bad ground, alternator going bad, loose battery connections, etc.
Edited by: Gizmo42
Old Jun 12, 2007 | 12:10 PM
cowboys78's Avatar
Yeah, I bet its the fuel pump/filter...I constantly ran the car on empty for 2 or 3 years...Only putting 5-10 dollars of gas in it each time...Must have burned it out...Still runs, just trouble with it
Lizrodeo00'
Apr 7, 2010 01:00 PM
redfinder
Dec 12, 2008 11:21 PM
dpotgieter
I-Mark
Apr 27, 2008 09:20 PM
Dennis
Dec 8, 2007 01:37 PM
vamootsman
Mar 14, 2007 12:26 PM
