94 Rodeo acting really weird!!! plz help
Old Jun 6, 2007 | 12:39 AM
cowboys78's Avatar
The car will lose power and die generally when Im going down a decline over the big bridge here where I live. Also, the car will buck 3 or 4 times with the "check trans" light flashing when I first start driving the car, then it seems to go away. Could it be the fuel filter or fuel pump going bad? Also, the volt needle on the battery indicator on the dashboard usually is on 14volts but now it wabbles back and forth between 13 and 16...Something is going wrong where the car isnt getting the power (or gas) it needs at certain times...Plz help me! Recently replaced the battery, timing belt tensioner, radiator, and valve gasket and plugs...Wanna get my moneys worth out of this car...thanks
Old Jun 7, 2007 | 04:00 PM
berryzn45's Avatar
Your coil packs may be going out. Also I have a question for you. I need to get some pics of your motor. I'm building one back up and don't know where all the bracket and accesories go on the front. Can you help me out.
Pikey
Nov 16, 2011 10:43 AM
mudsnipe
Dec 30, 2010 07:59 PM
99amigo2.2
Feb 17, 2009 11:00 PM
compfreak530
Sep 13, 2008 05:55 PM
rubbix
Impulse
Apr 1, 2007 03:59 PM
