93 Rodeo O2 Sensor
I replaced the oxygen sensor on my ''93 Rodeo 3.3 ltr. after the O2 light came on. I unhooked the battery for several hours to reset, but the O2 light is still lit. There is no sign of any damage to the wires. I only see the one sensor. Any help is apreciated.
In my 1994... (so might be a little different) the O2 light comes on at 80K. Doesn''t matter if it''s bad or not. The "light turn off procedure" involves removing the insturment cluster and moving a small ''set screw'' from one hole to another. That restarts the O2- 80K timer.
See rule 1 below.
Hehehehe... I''m not getting into that one...[img]smileys/smiley4.gif[/img]
But I will tell you (and anyone for that matter) that the real Factory Service Manual for any car is the ONLY way to go.
Most can be found on Ebay for under $100 (got mine for $80 in hard copy) and CD versions (if available) for less than $15. I got severalfor my domestic vehicles on CD, including my ''94 Explorer (it''s a POS) for under $10.
[img]smileys/smiley11.gif[/img]I will never buy a Japanese vehicle again. [img]smileys/smiley11.gif[/img][img]smileys/smiley11.gif[/img][img]smileys/smiley11.gif[/img]
I learned my leason.
