89 rodeo issues please help
Old Dec 15, 2009 | 06:33 PM
03fmv's Avatar
Exclamation 89 rodeo issues please help
Hi all
i have a 1989 holden rodeo 2.6 4ZE1 motor.
it starts and idiles fine but when driving out on road
when it gets between 2000-3000 rpm the motor shuts down then straight away comes back to life this repeats itself untile you stop then it just idiles fine like nothing is wrong
is it a sensor anyone else had this problem?
thanx in advance from merrik
Old Dec 16, 2009 | 09:40 PM
wheily's Avatar
sounds like ur cam or crank senser may be dying cant keep up a signal with rpm i think ther is a way to check them but im not sure how with out my manual but the sensers arent to exspensive id just replace them
Old Dec 17, 2009 | 07:09 PM
03fmv's Avatar
hi mate
cool where are the sensors/sensor located
thanks
Old Dec 18, 2009 | 01:24 PM
wheily's Avatar
well it showes in the manual that it is near the driver side moter mount. als says to use a volt meter and the reading should be 2.5 volts while engine is cranking . also i would check ur throttle position sesor *** that one may cause the problem too its on side of throttle body
powerismine
Nov 19, 2011 06:57 AM
outtamyway
Jun 13, 2010 07:45 PM
amc5
Oct 11, 2008 11:28 AM
tiburonxe
Jan 17, 2008 02:51 PM
4cefed4
Apr 7, 2006 06:42 PM
