4Wd Lo and HI
Old Aug 30, 2007 | 05:36 PM
IsuzuKid's Avatar
what is the difference between 4wd hi and lo and does anybody kno how much a power steering pump runs i have a 96 rodeo 3.2 sohc
Old Aug 30, 2007 | 06:01 PM
4hi is the same final gearing as 2hi but power to both axles. 4lo is reduced gearing for more torque at low speed. Take it out in the dirt (prefereably on some hills) and play with it. Will be obvious then.
Power steering pumps are about $100-150 depending on where you get it.
Old Aug 30, 2007 | 09:10 PM
IsuzuKid's Avatar
my car shouldn't get stuck in 4lo should it
Old Aug 30, 2007 | 11:19 PM
You mean your shift lever is stuck in low? If so then that is bad. Possibly a bent or broken shift fork in the t-case, not fun to fix. Dont know if a shift on the fly malfunction could cause that, I wouldnt think so.
Hopefully you werent using 4wd on dry pavement. Its not AWD and needs a loose surface (dirt or snow) so the wheels can slip a bit. Otherwise it can bind up and break parts. Not sure if that would cause that particular problem either.
Old Aug 31, 2007 | 12:32 PM
IsuzuKid's Avatar
no i mean it shouldn't get stuck in gravel or mud should i and how would i kno if my car was stuck in 4 lo
Old Aug 31, 2007 | 09:09 PM
Any vehicle can get stuck in anything at some point. Tires have the most to do with it. You will get stuck in mud alot easier with street tires then with mud tires. Lockers or limited slip can help some with not getting stuck but can still happen.
HERE are some pics of Mike and Myself stuck in the same mud hole at different times. Both of our trucks had good offroad tires and limited slip at the time. I have a locker in the rear of mine now which should help me a bit.
If your shifter was stuck in 4lo it would be obvious. Can only do about 20 mph in 3rd gear in low range (never had mine in a higher gear in low).
austintwede
Mar 17, 2014 12:21 PM
jamracer21
Mar 19, 2010 03:28 PM
chaindrive
Dec 28, 2007 11:33 AM
