2004 Rodeo Oil leak
I have a real bad oil leak that looks like it is coming from the front of the motor. It's collecting under the A/C compressor and traveling down the wiring harness. What could the leak be coming from in that location? I haven't really torn into it yet, but I thought I would ask around first. I know the oil pump/filter is in that area-any help is appreciated!
Thanks in advance!!
Robc
Thanks in advance!!
Robc
Rodeos are known for poor seals. They leak a lot. Can't be sure but I believe one of your seals is leaking. Had a similiar problem and used a
sealer I got from WALMART. Believe it or not, it actually worked. I can't
remember the brand but will check the next time I go to walmart.
