2002 Rodeo Sport clutch problem ??
Old Sep 7, 2006 | 12:27 AM
kilo's Avatar
I am new to automatic cars as I have always driven manuals. My 02 automatic Rodeo only has 53k miles on it I think I have a problem with the clutch not sure if it needs replacing? When you start off sometimes the car doesn't go straight away and then instant power and the wheels spin, also whilst driving when the car goes to change gear it sometimes changes there is a pause then the wheels spin. Any information would be a massive help and if you think the clutch needs replacing how much does this normally cost? Many Thanks.
Old Sep 7, 2006 | 01:17 AM
No clutch with an automoatic. Most likely the trans fluid is low. If it hasnt been done that you know of, have the trans fluid changed and filter cleaned/replaced. The 4L30E trannys in these trucks do not like to be neglected and need regular fluid changes.
Old Sep 8, 2006 | 02:27 AM
kilo's Avatar
Got the trans fluid replaced ($130) and filer cleaned, but after driving the car all day its still the same. Is it the timing of the shifter or is the transmition on its way out? Thanks.
Old Sep 8, 2006 | 12:14 PM
kilo's Avatar
Could it be the throttle position sensor or speed sensor, perhaps the trans isn't getting enough pressure or they didn't manage to quite fill the trans with fluid? Like I said in my firts post I am new to automatics so sorry for all the questions... Many thanks
Old Sep 8, 2006 | 01:16 PM
Since the fluid is good I would now suspect the range mode sensor. It makes the trans do funny things when it gets dirt. I can just be cleaned. I havent done it myself since I have a manual tranny.
Check http://forum.planetisuzoo.com/viewtopic.php?t=1707
There are several ppl on that board who have fixed theirs.
Old Sep 10, 2006 | 07:11 PM
kilo's Avatar
Ok cleaned out the range mode senor but it still hard shifts, nearly always from first into second and then when it downshifts into second. Any ideas? Many thanks
Old Sep 10, 2006 | 07:37 PM
Those are the only things that I know of that cause the symptoms you have. Doesnt mean that something else wont cause it, I just dont know what it would be.
Like you I dont have much experience with automatics. Never owned one and never will, I dont like them.
jbenne
IF Help & Suggestion Center
5
Mar 8, 2012 05:25 AM
TPhelps
Jul 27, 2011 05:54 AM
hunter13605
Apr 11, 2011 08:58 PM
RILES
Private 'Wanted' Classifieds
Jun 8, 2010 06:21 AM
Mike124
May 28, 2008 01:33 AM
