1998 isuzu rodeo
where is the ABS control module? Where are the ABS FUSES?
WHERE IS/ARE THE AIRBAG FUSES?
HOW TO TEST THE IDLE SPEED CONTROL VALVE/SOLENOID?
HELP!
THANK YOU, THE HAYNES MANUAL IS PRACTICALLY USELESS FOR WORKING ON THE 1998 ISUZU RODEO;..WHAT ELSE IS NEW OR CAN BE EXPECTED FROM A TYPICAL LOW QUALITY BRITISH PUBLICATION!!!
The Haynes manual is way better then the Chiltons but yea, its lacking on the 2nd gen info.
Go to...
http://rapidshare.com/files/167488811/Rodeo99.pdf
I just uploaded the factory manual there, should be there for 90 days. ''98 and ''99 are exactly the same.
Oh, abs module is in the engine compartment on the passenger side with all the metal tubes going to it. The abs fuse is in the engine compartment fuse box by the battery, the srs fuses are in the dash fuse box with the yellow plastic things around them. You''ll have to get the manual and look up testing the IAC.
Go to...
yhperformance
Aug 29, 2008 03:17 PM
