-   -   1997 Rodeo Stalls out at high speed? (https://isuzuforums.com/forum/rodeo-17/1997-rodeo-stalls-out-high-speed-36172/)
leejm12 May 25, 2010 12:47 PM
I have a 97 rodeo - Automatic that has stalled out at 30 MPH and 50 MPH. Symtoms, driver display panel lights up all lights, engine shuts off completely, just like turning off the ignition key. Then it can restart immediately. No DTC codes. Checked the IAC - very dirty and cleaned it.
EGR looks pretty dirty and will check this weekend. Any ideas what might
cause this? Thanks, -J
g2turbo May 26, 2010 05:00 PM
Ensure the battery cables are clean and most importantly tight. Battery should be good and secured.
Check all fuse panels for any melting, you'll smell it when sniffing around.
If it's from the salt-belt regions, especially check and clean the various ground contacts.
If all that checks out, then consider swapping out the ECM for a known good one.
Sounds safe to assume the ignition switch is okay....
leejm12 May 27, 2010 09:50 AM
Thanks, I was thinking ECM as well but in the Haynes book, there isn't any information about testing it. So I may try swapping it out. Thanks again. -J
