1997 Rodeo Stalls out at high speed?
Old May 25, 2010 | 12:47 PM
leejm12's Avatar
Unhappy 1997 Rodeo Stalls out at high speed?
I have a 97 rodeo - Automatic that has stalled out at 30 MPH and 50 MPH. Symtoms, driver display panel lights up all lights, engine shuts off completely, just like turning off the ignition key. Then it can restart immediately. No DTC codes. Checked the IAC - very dirty and cleaned it.
EGR looks pretty dirty and will check this weekend. Any ideas what might
cause this? Thanks, -J
Old May 26, 2010 | 05:00 PM
g2turbo's Avatar
Ensure the battery cables are clean and most importantly tight. Battery should be good and secured.
Check all fuse panels for any melting, you'll smell it when sniffing around.
If it's from the salt-belt regions, especially check and clean the various ground contacts.
If all that checks out, then consider swapping out the ECM for a known good one.
Sounds safe to assume the ignition switch is okay....
Old May 27, 2010 | 09:50 AM
leejm12's Avatar
Thanks, I was thinking ECM as well but in the Haynes book, there isn't any information about testing it. So I may try swapping it out. Thanks again. -J
wtcure
Ascender 5- and 7- Passenger
4
Mar 6, 2011 07:52 PM
dray2n
Feb 1, 2011 11:38 AM
2000 rodeo guy
Jan 15, 2011 06:02 PM
robby
Jul 26, 2010 04:32 PM
lucky guy
Oct 3, 2009 01:10 PM
