02 Rodeo Sport
Old Dec 3, 2008 | 10:03 PM
nacho-rodeo's Avatar
Ok, so check this out. The fools I bought this thing from tried to powerwash the engine. A friend has a codereader thing and we couldnt even get a code till I replaced the plugs and sprayed a drying agent on all the connectors and now I keep getting (reduced power) and (engine light), can anyone help me out on this one?
Old Dec 3, 2008 | 11:56 PM
Power washing the engine shouldnt cause any problems. I do mine several times a year, always have.
What spark plugs did you use? ''02 has ion sensing ignition and uses the plugs as sensors. You have to use specific plugs with them. One is Denso K16PR-P11 there is also a champion plug that works but I hate champion plugs so never paid attention to the number.
Old Dec 4, 2008 | 06:09 AM
ngk platinum spark plugs, there was a little moisture in two plugs and I could see where they wasnt sparking right and needed to be replaced...
Old Dec 6, 2008 | 08:48 AM
Mean_Muggen_420's Avatar
If it is idling rough you might want to check the vaccum lines for any leaks, maybe when the power washed the engine could have possibly knocked a hose loose and if you do power wash your engine you should be very careful on how you do it or take it some where so if the f**k it up then they have to fix it.
Old Dec 6, 2008 | 09:07 AM
Thanks, it runs fine the thing thats going on is an engine light and a reduced power light that comes and goes.
Old Dec 6, 2008 | 07:02 PM
Go to autozone and have them check the CEL codes. They will do it free. Write down the nubers that come up and post them here. We should be able to figure out where to go next. If possible have them clear the codes, then if the CEL comes back on get them read again. This way you dont get old codes that are no longer a problem.
Old Dec 6, 2008 | 07:38 PM
Thanks.
Old Dec 7, 2008 | 03:08 PM
  #8
OK, here''s the codes.
P1125 P1285 P1275 P1120 P0452 P0106 P0405
Old Dec 8, 2008 | 06:51 PM
  #9
Well I found a couple possibilties with common codes to yours. One seems to be pretty easy to fix, the other... umm.. sucks.
Here are links to the threads...
http://forum.planetisuzoo.com/viewtopic.php?t=8937
http://forum.planetisuzoo.com/viewtopic.php?t=14426
http://forum.planetisuzoo.com/viewtopic.php?t=14604
http://forum.planetisuzoo.com/viewtopic.php?t=11539
Its somewhere to start at least.
Old Nov 13, 2012 | 04:55 PM
  #10
TonlRinla's Avatar
Banned
Video: A Night With JONONE|
Our friends from BKRW have produced a nice new video feature and spend one night with artist JONONE. Enjoy!
breguet replica paypal rado coupole replica watches longines presence watch
NEUWBEA
May 6, 2010 04:04 PM
Mike124
May 28, 2008 01:33 AM
kilo
Sep 10, 2006 07:37 PM
thenry
Sep 11, 2005 09:06 PM
Doughboy
Mar 7, 2005 05:42 PM
