Headlights going out 88 pickup 2.6 liter
I was driving the other night and noticed my low beams both had gone out, so i switched to high beams and they worked fine. The next night I went and got totally new headlights and installed them. Tonight I was driving home and my low beams flickered and went out at the same time, then my high beams right after that. I checked my fuses and everything looks ok. Any suggestions?
There are only two likely culprits. the headlight switch and the dimmer switch. USUALLY if it's the dimmer switch, you'll have either high or low beams. Loss of all lights usually indicates a bad headlight switch.I have seen both sides of a dimmer burn out, but it is rare. If your lights work for a while then quit it's almost always the headlight switch.
Mike11
Nov 3, 2009 02:31 PM
SGcvn69
Apr 26, 2008 02:22 AM
