92 Isuzu pickup 2.6 EGR issues and running rich
Old Jan 16, 2022 | 11:28 PM
Scricer's Avatar
Default 92 Isuzu pickup 2.6 EGR issues and running rich
Hey guys,
Bought a 92 pup 2.6 spacecab 4x a few months ago and been replacing just about everything I can. I’m having issues with a misfire/running badly that are being caused by the egr valve.
My plan is to cut a piece of aluminum flashing to the shape where the egr bolts on and seal it with high heat caulking. And for the hose that goes to the egr I planned on just stuffing something in and clamping it.
Does anyone have any better ideas? I could also just weld a plate onto where the egr mounts but I’d rather not do that.
The truck also runs a little rich, you can smell it sometimes. I was told that the evap is the most likely cause but any parts store I’ve called has said that their system is saying that these trucks don’t have a Vapor canister and rockauto says the same. If anyone has any insight on this please feel free to share as I’m at a bit of a loss.
Work done so far;
All fluids; oil, transmission, diffs, tcase, coolant (not power steering yet)
Spark plugs
Plug wires
Fuel filter
Clutch master and Slave cylinder
Distrubutor cap + rotor
Waiting on MAF, O2 sensor, air filter and PCV to arrive.
The pcv might also help the running rich issue but just curious.
thanks guys!
kenlang
Pickup
Oct 29, 2020 08:19 AM
machielr
Dec 27, 2013 12:11 PM
skully1
Mar 30, 2009 11:22 PM
magickninja
Pickup
Nov 10, 2008 04:41 PM
futuresweets-10
Pickup
Apr 23, 2007 10:49 PM
