How to Convert MTS/M2TS to iMovie on Mac
Old Sep 5, 2012 | 10:30 PM
windyjhzt's Avatar
Default How to Convert MTS/M2TS to iMovie on Mac
Nowadays, making a home movie by ourselves is not a dream. Everything can be realized by some smart softwares easlilimovie icony. For mac users, iMovie is the most familiar video editing tool. When you record some video clips by your Sony or Canon camcoder, you may want to convert MTS to iMovie and begin to edit. Oops! Erros appear. That's a normal problem. Because the video clips recorded by your camcoder may be MTS/M2TS format which is incompatible with iMovie.
Then what should we do? Video Converter for Mac is a helpful video converting tool which can make MTS/M2TS to iMovie conversion on Mac OS easlily. It is able to solve almost all your video and audio incompatibility probelms with high efficiency. With this powerful program, you will have a better video and audio enjoyment from now on.
Note: To make you know more about the conversion, we provide a tutorial for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
Detailed tutorial about MTS/M2TS to iMovie conversion on Mac
Freely and safely download the Video Converter for Mac and try to make the conversion step by step a below.
buy video converter mac download video converter mac
Step1. Load files into this MTS/M2TS to iMovie Converter
This program provides you two methods to import files.
1. Go to "File" menu on the tool bar and click "Add Files" to load videos.
2. Directly drag the selected MTS/M2TS videos into the program.
For user' convenience, batch conversion is supported too.
mac video converter main interface
Step 2. Select the correct output format
Please click "Output Setting" icon ->Format ->Apple Software ->iMovie and, then you can convert videos to the iMovie supported format.
mac video conveter mts to imovie output format interface
Step 3. Start MTS/M2TS to iMovie conversion on Mac
Click ''Convert'' icon, all the tasks will begin with high efficiency.
mac video converter conversion interface e05
Tips on MTS/M2TS to iMovie Converter:
1. You can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the "Output Setting" menu to make the output video better. If no need, you can just keep the default parameters.
2. If you make batch conversion, you can set the "After conversion" mode on the conversion interface. It provides you "Put computer to sleep", "Shut down my computer" and "Do nothing" three mode options.
mac video converter after conversion interface
3. This program also has video editing features, you can trim, crop, merge the videos and add subtitle and watermarks to make the output videos more special. If you are interested in the video editing functions, you can click the edit icon and try to make use of it.
windyjhzt
Sep 7, 2012 12:04 AM
windyjhzt
Sep 5, 2012 12:04 AM
windyjhzt
Sep 4, 2012 12:25 AM
windyjhzt
Sep 3, 2012 12:42 AM
