Buying a home which the seller is listed "as is."
Old Mar 8, 2013 | 03:01 AM
ash1990's Avatar
Default Buying a home which the seller is listed "as is."
A bank doesn't require you to get a home inspection in order to obtain a mortgage. If there are obvious major problems that affect value, the appraiser may note it in the appraisal report. However, their job is not to inspect the home, just to determine value. Although the bank doesn't require a home inspection, if your purchase contract mentions a termite report, the lender will require that to be performed and pass before you close. A termite report lists more than pest infestations. It also mentions obvious structural defects, such as wood rot, etc. These are classified into two groups - category 1 and 2. All items in category 1 must be repaired prior to closing. However, the lender does not stipulate who must pay for those repairs.
________________
Cheap Removals
ash1990
Jan 17, 2013 06:02 AM
easylead
Oct 26, 2011 06:12 AM
Pitter
Dec 27, 2009 04:58 PM
krichart
Pickup
Jul 2, 2009 07:47 PM
