need clutch help
Old Oct 29, 2008 | 09:08 PM
steven0000's Avatar
i have a 92 isuzu pickup regular cab
and my clutch petal was sticking to the floor
and the clutch pedal worked fine and never stuck when the engine wasn''t running
so i knew it was the actual pedal and it was something inside the transmission
so i dropped the transmission to change the throw out bearing, pressure plate, and put a new clutch in
when i looked at the old throw out bearing the pressure plate had been eating away at it
so i put a brand new pressure plate, clutch and throw out bearing in it
and put everything back together
now the throw out bearing does not seem to be be pressing against the pressure plate
because i can move the arm the clutch cable attaches to by hand
when before i had to use a lot more force
and when i press down the clutch it is much easier and then just sticks to the floor when not running
it sticks in the same way that it would if the clutch cable was not attached
any information and questions are welcome
steven0000
Pickup
Nov 2, 2008 10:37 AM
brian williams
Aug 6, 2008 12:02 AM
Monster Truck
Jul 11, 2008 03:18 AM
c20xe
Apr 5, 2008 07:21 AM
trooper90
Dec 1, 2006 04:49 PM
