Isuzu Pickup, i-350 and 1-280 Talk about Isuzu Pickup related topics here...
Solve the center position of ISUZU C07104B steering angle sensor
Old Jan 1, 2023 | 09:31 PM
Victor668's Avatar
Default Solve the center position of ISUZU C07104B steering angle sensor
When I start my ISUZU DMAX 2016, it does not work normally. A few dashboard displays will appear. I’m trying to use X431 V+ to diagnose it and solve the problem.
I select ISUZU software and search automatically, it says this function only supports models since year 2008 at the moment. Please enter the test from the year model menu for the previous models 2008. I click OK to go to the system selection page and select ABS/ESC/AEBS to read the fault code, read fault code C07104B which means that the center position of the steering angle sensor is invalid. Then I clear the fault code, it shows that the fault code has been cleared, but when I read the fault code again, the fault code is still on the screen. How to deal with it?
obd2.ltd engineer replied:
After reading the fault code by X431 Pro3, go to Special Function-> Learning for Steering Central Position
Then click ‘Clear’ at the bottom left of the corner
You will get the prompt ‘execute successfully!’. Then go to clear fault code again.
If you have any other questions, Email: Sales@obd2.ltd
D16z6
Pickup
14
Nov 24, 2013 10:58 AM
harleybob
Sep 1, 2011 07:15 PM
iceman_nc
Dec 31, 2007 05:39 PM
wantabe
Pickup
May 25, 2007 11:13 AM
dane
May 31, 2005 06:19 PM
