Interior What have you done to the inside of your ride? Customized it...? Kept it super clean...? Talk about it here...
Door lock Jammed...
Old Oct 31, 2012 | 11:26 PM
Braid13's Avatar
Default Door lock Jammed...
I want to unlock the car's door with the key but I couldn't do that. I tried it again and again. Even that I was using the right key. So I go to the passenger door and unlock it just fine. The lock and unlock button works on both doors only it locks and unlocks the passenger side door only. But the driver side dook is going to jammed and never open with key or from insider.
What i have to do in this situation....?
Old May 22, 2013 | 03:50 AM
simonjames's Avatar
Counts on the kind of secure. A keyed entry lock needs, when locked, a key to operate; if you have such a key, it should work. A privacy secure has on the out-of-doors a little hole, in which a thin object such as a Q-tip or unfolded paper clip can be inserted to trip the mechanism.
reybie
Apr 1, 2009 12:38 PM
REDUZU
Dec 14, 2008 05:27 AM
iflyboy
Isuzu Pickup, i-350 and 1-280
Apr 3, 2007 07:09 AM
G-Man
Dec 28, 2006 01:22 AM
kleners
Apr 13, 2006 09:02 PM
