-   IF Help & Suggestion Center (https://isuzuforums.com/forum/if-help-suggestion-center-12/)
-   -   oil pressure (https://isuzuforums.com/forum/if-help-suggestion-center-12/oil-pressure-564/)
bmck Sep 10, 2006 09:03 PM
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
have a 1996 trooper w/3.2L motor, recently purchased, has no oil pressure when warm, apprxo, 45 psi when cold, engine has slight rattle at idle, louder at 2000rpm,installed new oil pump, new pump did not help the problem, motor run goods, have tried numerous oil additives &amp; no help, any ideas? Main bearings? would heavier oil help or hurt?
nate783 Nov 18, 2006 03:59 AM
i have had very similar problems with my 94 rodeo with a 3.2, mine ended up being rod bearings were very worn and caused the drop in oil pressure, my current rodeo has the same problem now, i run 4 quarts of mobil 1 15w-50 with 2 quarts of lucas heavy duty oil stabalizer and it made it happy and all has been well for about 1 year now, hope that helps
ISUZUGURU Nov 19, 2006 03:03 PM
the older isuzus,esp96 95 94,the oil pressure gauge normally reads low when hot.isuzu has a service bulliten for this problem theres no corection for it.just they say its normal.before spending alot of time,be sure to check it with a mechanical gauge.
