My clutch just says no go....
Old Jan 6, 2010 | 10:03 AM
lookingtolearn's Avatar
Default My clutch just says no go....
First of all I am new to this forum and I often don't understand anything about Mechanics. I am a noob if you will. I want to learn however and even though this is a specific problem I am just looking for an overall idea so I can try to self manage. Okay, So here is whats going on.
I have a 92 Isuzu Amigo 5 speed. Its one hell of a ride. Just love the poop out of it. However, I don't ride my clutch and I am great at manual. About a week ago I went out to start it up and it decided that my normally tight sexy clutch was going to become an loose sloppy clutch. I would slam it to the ground before it would decide to release the gears for me. I didn't understand much about it. I was told that it could be a fluid problem and after being kicked out for asking too many questions at kragen I filled up my low hydraulic fluid. Its doing the same thing on a slightly smaller scale (still can't drive it).
Any ideas on what else it could be ( told you i suck)?? If so Can you give me a rough description on how to check. I can google the car parts and figure out what is what so no need to describe the looks just the process. Thank you guys. Im hoping to start my new years a little more car savvy!
Old Feb 1, 2010 | 05:04 PM
ronnny's Avatar
Can not remember if the slave cylinder is internal or external (in or out of the bell housing) But look for fluid leaks around the clutch and fix that. Then you bleed all the air out of the line like bleeding brakes. Somewhere there is a leak.
jonas685
Oct 19, 2012 03:46 AM
jonas685
Oct 19, 2012 03:45 AM
joenoble
Nov 14, 2011 10:03 PM
David Warner
Jul 22, 2011 10:48 AM
