engine overheat with new thermostat but not when removed
Old Feb 13, 2016 | 08:41 AM
amytre's Avatar
Default engine overheat with new thermostat but not when removed
I have a 2.2 with a new head gasket, rebuilt head, water pump. The issue is that the engine runs hot with my new and old thermostat. The antifreeze is cool be but engine hot, it seems like was it restricted. Here's the kicker when I remove.the thermostat it run just.fine what can cause the problem
Old Apr 3, 2016 | 12:12 PM
Ryan Mueller's Avatar
you have a blockage somewhere. coolant only runs through the thermostat one way (like a check valve) so when you remove it the coolant is allowed to flow backwards through the engine which is why your not overheating without one.
Itsatrooper
Jan 23, 2016 08:11 AM
e207
Apr 29, 2015 08:40 PM
matt922
Nov 6, 2008 05:06 PM
Ringwraith2000
Jan 26, 2008 05:15 PM
