-   IF Help & Suggestion Center (https://isuzuforums.com/forum/if-help-suggestion-center-12/)
-   -   97 Rodeo will not started with the ignition switch (https://isuzuforums.com/forum/if-help-suggestion-center-12/97-rodeo-will-not-started-ignition-switch-34805/)
Gundam79 Jul 4, 2009 12:52 AM
I have a 97 Rodeo LS 2WD with 3.2 v6. Never had electrical problems. The engine went out so I replace it with a used Honda Passport 3.2 v6. So I put in the engine and it will no started with the ignition switch. But I can jump the starter and it runs. Some of the lights stay on on the Instrument panel like the changing light. With the car runing the battery is putting out 11.5 volts. The 100amp main fuse has power w/o the key on and will blow the fuse. Do any one have a idea whats wrong with this suv ?
