I-Mark Talk about Isuzu I-Mark related topics here...
my car when under stress just boggs...
Old Jun 8, 2006 | 10:19 PM
isuzu_racer's Avatar
can anyone help me because i have checked the compression and the fuel pressure and they both seem to be fine. by the way i have a 1989 i-mark rs. i dont know much abouit fuel injection so i am open to any help at all thanks.
-travis-
Old Jun 12, 2006 | 03:19 PM
ISUZUGURU's Avatar
Super Moderator
what was the compression an fuel psi reading you got?
it should be at least 50 for fuel pressure at alll times.an compression should be 150psi all clyinders.you may want to do a exhaust back psi check also when hot an cold.converter may be clogging
Old Aug 26, 2006 | 08:06 PM
Takumi's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
IsuzuGuru is right you might want to do a vacuum test as well, if the vacuum doesnt go back to normal if u rev it at 2-3k rpm for 5 sec'ishmost likely u have a clogged cat or too much restriction in exhaust system.
jessijo821
May 5, 2012 01:12 AM
DavidCamron77
Feb 14, 2012 04:36 AM
airenbrown
Nov 21, 2011 04:29 AM
Steezy
Mar 11, 2011 02:52 AM
turbine
Impulse
7
May 2, 2007 06:01 PM
