Need an Isuzu Guru to figure this one out
Old Feb 16, 2007 | 12:01 AM
87STANGMAN's Avatar
Ok guys here is the deal and my first post on these forums. I am at my witts end with this one 92' Isuzu Rodeo 2.6L 4cyl 5SPD my dad owns. I am not used to working on forien autos but I do have many, many hours/years on domestics. To make a long story short I replaced a blown head gasket after we finished up the work the truck will fire but is then drowned by raw fuel. When I say raw, I can take out the spark plugs and gas will spray out when the motor is turned over as if the injectors are stuck open. I have gone through wiring diags and vac. diags and checked all grounds to no avail.
Old Feb 16, 2007 | 09:31 PM
MASTERTECH's Avatar
did you remove the dist, if so what number did you place the dist on, if #1 that is wrong you place it on #4, lets start there first
Old Feb 17, 2007 | 01:12 AM
87STANGMAN's Avatar
Hmm, you mean as far as which cyl it fires on first? I did set it to #1, your saying it should fire on the #4 cyl first?
Thanks for all help in advance
Old Feb 19, 2007 | 09:30 PM
MASTERTECH's Avatar
yes set it on #4 with the crank and cam on the timing marks, they will be both straight up, let me know if this cures your problem
CjYARBOROUGH
Intake, Headers and Exhaust
5
Jan 14, 2010 11:37 PM
CjYARBOROUGH
Computer and Fuel Systems
Mar 28, 2008 09:40 AM
tide_belle
Jun 24, 2007 10:44 PM
CjYARBOROUGH
Jun 11, 2007 07:51 PM
