Just Got Isuzu Motor. need info about it
Old Oct 8, 2006 | 07:32 PM
hodgoes2001's Avatar
Hey all. this is my first post on this forum. I wasn't sure where to put this so i though this is a good as place as any. I am wondering if someone
can give me some info on a Isuzu motor i have just bought. all i know
about it is the Engine Number "5-075-1B" so far i haven't been able to
find anything. any info that anyone can give would b handy. I know it
is a pretty old motor 4 starters. i got it in a Series 3 Landrover. and
i am looking at transfering it into my Series 3 Landrover Game Limited
Edition[img]smileys/smiley16.gif[/img]. Mainly because the orginal motor is pretty much shot. if
anyone else has this motor in there Series 3 Landrover. i would like 2
know how u put it in. because the current way that it is installed into
the other one is kinda a bit scrapy. anyway thanx in advance.[img]smileys/smiley1.gif[/img]
Old Oct 18, 2006 | 10:25 PM
Righto. i have finally got some pics to show. so here u go. btw i couldn't get much better angles then that. because the motor is still in another Series 3. like i have already said. also i do have higher quality ones but well i only have dial-up so i shrank them down so they wouldn't take to long to upload or view
As u can c defently a Isuzu. oh yeh i know it is missing it theromsat as well.
Old Nov 15, 2006 | 05:58 PM
nate783's Avatar
what year is that engine? i have some books on isuzu 4cyl engines so if you let me knwo that year i may be able to give you some specs on it
Old Nov 15, 2006 | 11:52 PM
well thats my prob. i have no idea what year model it is. only the engine number. thats about it.
Old Nov 16, 2006 | 03:09 PM
nate783's Avatar
Form the pictures i have in the manuals, they dont seen to look the same as the engine you have, most of the info i have is on the Isuzu 4ZE1, and that doesnt appear to be that same, i think yours is older, sorry i couldnt help
Old Nov 16, 2006 | 06:46 PM
Just wondering. what year model are the ones that u r talking about??
Old Nov 17, 2006 | 02:50 PM
nate783's Avatar
the books are titled 1989 but i believe that it was a good span of years that they used this motor, in case your curious, i'll just post some information on it anyway this is general info, let me know if you want something more specific,
Engine: Water cooled, cross folw, microcomputor contolled, fuel injected, SOHC, belt driven Cam
Combustion Chamber: Hemispherical type
Bore x Stroke: 92.6mm x 95mm (3.64 x 3.74)
Displacement: 2.559Liters (156.2ci)
Compression ratio: 8.3:1
Engine Dimensions (LxWxH): 682x595x743mm (26.9x23.4x29.3in)
Engine wieght (dry): 153kg (337.4lbs)
Intake valves open at (13 degrees) BTDC
closed at (61 degrees) ABDC
Exhaust valves open at (67 degrees) BBDC
close at (27 degrees) ATDC
Valve clearances: .20mm(0.008in)
Valve head diameter: Intake-----44.2mm(1.74in)
Exhaust----37.0mm(1.45in)
Ignition type: point-less
Advance device: electronics control
Method of ignition: full transistor battery ignition
Ignnition timing: 12 degrees BTDC @ 900RPM
Firing order: 1-3-4-2
Spark Plugs: NGK BPR 5ES-11/AC.R43XLS
Spark plug size: M14 P=1.25 (0.050in)
Spark gap:1.05mm (.040in)
Oil pump: Trochoid type
Delivery volume: 38.1 liters/min (10 gallons/ min)
@2760RPM
pressure of delivery: 56.9psi @50degrees C or 122F
Oil capacity: 4.9liters (5.2 quarts)
crankcase without filter: 3.8l (4.0q)
crankcase with filter: 4.2l (4.4q)
Radiator cap opening pressure: 1.05kg/cm2 (14.9psi)
Water pump type: Centrifugal impeller type
delivery volume: 190liters/min (50gallons/min)
@6000 RPM
Thermostat type: Wax-pellet with jiggle valve
openeing temperature: 82C (180F)
Fan pulley ratio: 1.23:1
Fan outside diameter: 410mm-7blades with clutch
Charging system type: Stator diode recified alternator
drive and roation: v-belt, clockwise viewed from front
speed ratio to engine: 2.14:1
regulator type: transistor
Starter type: Soleniod control with overrunning clutch
Starter gear ratio: 9:115
Distributor type: Photoelectric type with integrated crank angle sensor, electronically controlled advance
hopefully some of that mess will help you out, if not hopefully it will help out someone else on the forum, and like i said , if you need something more specific, let me know, GOOD LUCK!!
Steezy
Oct 7, 2012 05:27 PM
shadow_tek001
Oct 24, 2011 07:18 PM
technojock
Jan 20, 2009 12:43 AM
crazyindian
Jun 6, 2008 02:16 PM
rob5080
Feb 13, 2008 02:53 PM
