help timing '99 3.2
Old Jun 26, 2009 | 11:50 AM
tjhennin's Avatar
Default help timing '99 3.2
I've got a '99 3.2 and I had a water pump issue. I replaced the pump and changed the timing belt but can't get it to run right. I followed the instructions in the book, but still not right. I can get the crank pulley at the 3 o'clock position. The cam sprocket on the right cam bank (left side of the motor if facing the front of the car) I can't get to land on the timing mark on the valve cover. As I turn it clockwise, it clicks and pops as it should, but no matter how many times I spin it, I can't get it to stop naturally on the mark. I can get it to land a couple of teeth to the left or to the right, but not on. The right side however is fine. Any other suggestions on timing this thing?
Uticon
Mar 26, 2011 07:38 PM
tjhennin
Jun 24, 2009 10:20 PM
93green
Jan 30, 2009 12:10 AM
lorenwalding
May 16, 2008 01:58 PM
trooper90
Dec 1, 2006 04:49 PM
