head gasket leak
I have a 1986 pup 1.9 engine that always leaks water into the no.1 cylinder when you change the head gasket.I have changed blocks and heads with no luck.The only way to stop it is with loquid glass in the radiator.Would appreciate some ideas on this problem.
