Engine cutting out
Old Nov 5, 2007 | 10:58 PM
Bartamus's Avatar
My 92 3.2 trooperlooses powerand the engine almost dies after about 10 miles or ten min of driving, turning off the ignition seems to reset somthing and I am able to drive for another few min then it has the same trouble again. I have replaced the IACM, plugs and filters
Help me!!![img]smileys/smiley6.gif[/img]
Old Feb 5, 2008 | 07:04 PM
1TLB's Avatar
How many miles are on the Trooper? Sounds like a fuel problem.
Old Mar 14, 2008 | 06:37 PM
isuzunj's Avatar
do u get a check engine light
Old Mar 15, 2008 | 05:23 PM
ISUZUGURU's Avatar
Super Moderator
any check engine lights? check fuel psi when fuel pumps go bad they loose volume you may can hear it humming but that doesnt tell you much,get a fuel psi gauge from local parts store with a long hose,tape it too your windshield an drive it until problem happens again.if fuel psi falls below 20_30psi while driving its not enough it need at least in the 40psi range.approx 38 at idle.clogged fuel filter also can cause low psi
_uacct = "UA-939292-44";
Old Mar 15, 2008 | 05:27 PM
ISUZUGURU's Avatar
Super Moderator
also if fuel psi is good,clogged catlytic converters or converter,will cause a really bad power lose,you usaully notice the tone of the engine sounds different like somthing clogged inthe air box,you can have the pedal floored but the truck doesnt move over 20mph
94IT
Jul 28, 2011 03:27 PM
emailhemphill
Mar 20, 2010 10:54 AM
towingwithmyisuzu
Aug 5, 2009 03:05 PM
oxyman
Apr 24, 2009 06:05 AM
GIRLIEGODDESS
Jan 29, 2009 01:50 PM
