Belts STILL squeak!!!
Hey all. I have a 1994 Isuzu Rodeo. The belts squeak real loud. It used to stop after a minute or so, but now it keeps going. This is what I've done:
1. Changed all the belts. - Still squeaks
2. Changed the Water pump. - Still squeaks
3. Changed the alternator. - Still squeaks
What else is there to change? Can the pulley really be that loud?
Thanks.
Thanks.
Which motor do you have?
Do your adjustment points still have thread travel left(can you make them tighter)?
If you can tighten them more, do it.
If you are at the end of your tensioners range of travel, You have the wrong belts.
I had this same thing on my Trooper. Parts store gave me the wrong belt.
Is it an actual squeak? or is it a squeal? If it is a constant squeal, it may be a bearing in one of your pulleys
Also, it seems more like a squeal. I will tighten the alternator belt in the morning and see what happens. Thanks for the help
