94 V6 TIMING
Old Mar 8, 2008 | 02:32 PM
VAGABOND's Avatar
I HAVE A 94 V-6 RODEO. I REMOVED TIMING BELT BEFOREREADING MANUAL TO REPLACE WATER PUMP.I MARKED THE TIMING BELT AND NOW IT WONT LINE UP TO MY MARKS WHEN I PUT IT BACK ON. WHY WONT IT LINE UP? I DID NOT REMOVE PLUGS OR ROTATE CRANK OR CAMS BEFORE REMOVING BELT. THE HAYNES MANUAL SEEMS A LITTLE UNCLEAR TO ME AS TO HOW TO RE-TIME THE CRANK AND CAMS. I UNDERSTAND TO REMOVE SPARK PLUGS. ROTATE THE CRANK SO AS TO HAVE KEY WAY A 3 0'CLOCK POSITION (BEING CAREFUL NOT TO DAMAGE VALVES)THEN I AM NOT TO CLEAR AS TO THE MARKS OR ROTATION POINTS OF CAMS. I HAVE A LINE ON EACH CAM WITH A GREEN PAINT OVER THEM, ARE THESE THE TIMINGPOINTS? WHAT TO DO?
_uacct = "UA-939292-44";
waphill
Oct 5, 2012 03:19 PM
ephebus
Sep 8, 2006 03:18 PM
Thumper
Jul 2, 2006 06:25 PM
Keytonic
May 21, 2006 04:43 PM
stuwiley
Jan 13, 2005 10:19 PM
