2014 DMax air con cutting out when engine hot
Old Jan 22, 2024 | 01:30 AM
tinribs's Avatar
Question 2014 DMax air con cutting out when engine hot
Any clues to find the cause of the air conditioner shutting off when the engine temperature in my 2014 Isuzu DMax increases to about 'mid gauge' right about when you most need it with ambient temperature around 30 degrees plus. With an after market OBD monitor, engine temp is around 100 degrees C. When temp reduces below mid point, A/C unit comes back on. All control switches work fine, gas level checked OK, belt tension OK, Everything works as it should just not when engine gets warm/hot but not overheated. I am thinking maybe electronic thermostat but that's only a guess as I can't seem to put a finger on anything else as the culprit. Any thoughts or similar experiences welcome. Thanks.
Old Feb 11, 2024 | 10:42 PM
tinribs's Avatar
Found the culprit and fixed it. I haven't come across this one before however with a bit of lateral thinking it's all done..
Old Jan 24, 2025 | 02:05 PM
hajirashid's Avatar
Default Find Local Women Ready to Have Fun in Your City
Dating for Sex.
Best realistic adult game
Travistrooper
Dec 17, 2023 03:05 PM
Victor668
Mar 20, 2023 04:30 AM
klint01trooper
Aug 5, 2010 07:59 AM
denmex
Nov 2, 2009 11:04 AM
sharring
Oct 29, 2007 05:26 PM
