1991 pickup
Old Mar 14, 2009 | 01:34 AM
skully1's Avatar
Default 1991 pickup
I have a 1991 isuzu pickup with a factory 2.6L engine. When the truck is dropping from a high idle like coasting to a stop with the clutch pushed in the trucks idle will surge, I changed the TPS and this had no affect. Anyone have any ideas of what my problem might be? Thanks, Justin
Old Mar 30, 2009 | 11:22 PM
Moutain_Ox's Avatar
that would be your idle control valve. your truck is revs up an down. try taking it off an cleaning it out. they get gummed up an gunked up by oil. try some carb cleaner thru it. also if you dont want to take it off. shoot some carb cleanner down the intake. that will do the trick as well. make sure to use the straw that come with the cleaner. you dont realy want to get it on your air mass meeter. slip the straw in past the air meeter with the truck running at an idle an just spray until the truck dies then let it sit for ten mins fire it up, an spray little shots till your can is empty. an all sould be well, if not you need an icv .
cmonk
Feb 21, 2007 10:30 PM
cr0nus85
Jul 4, 2006 01:21 PM
GINAV
Apr 17, 2006 06:35 PM
kajuman
May 8, 2005 01:13 AM
bbusbee
Jan 3, 2005 04:12 PM
